G
Gritishbasspark
Hi guys, had a job given to me to wire up some diesel tanks on a farm they're plastic bunded tanks sitting on the ground, the pump is on the wall next to it strait forward line neutral and cpc. I've put the supply on an RCBO and have a rotary isolator next to it. Now as far as bonding goes I have some metal pipe joining the tank with the pump but as this is not likely to bring in it own earth potential so wasn't going to bother. Is there anything else I need to think about and do I need any special certificate for this circuit or will a standard one do.
Many thanks
David
Many thanks
David
