difference between a PT(Potential Transformer) & CVT (Capacitor Voltage Transformer) | on ElectriciansForums
Discuss difference between a PT(Potential Transformer) & CVT (Capacitor Voltage Transformer) in the Australia area at ElectriciansForums.net
speedtronic
What is the difference between a PT(Potential Transformer) & CVT (Capacitor Voltage Transformer) ?
Re: difference between a PT(Potential Transformer) & CVT (Capacitor Voltage Transform
Hey. Easiest way to explain it is that a PT uses windings to reduce output voltage on the secondary side just like a work site transformer - really heavy yellow box that you plug 110V site tools into.
CVT's on the other hand use 2 capacitors in series to drop the voltage via "cap and coil" circuits on the primary side They also have a choke coil that cancels out the "caps" for the phase shift between the primary and secondary of the CVT and inhibitors that get rid of voltage spikes and any back feeding on the HV line.
Cheers
Reply to difference between a PT(Potential Transformer) & CVT (Capacitor Voltage Transformer) in the Australia area at ElectriciansForums.net
