Different consumer units | on ElectriciansForums
Discuss Different consumer units in the UK Electrical Forum area at ElectriciansForums.net
H
Hammy
Hi guys, doing a rewire for a friend. Where the consumer unit is now is quite a narrow cupboard. Fitted now is a 16th edition 6 way contactum board. House is getting extended eventually and need to leave room for a couple of new circuits and also spare. No way cupboard can go wider, can make it higher though. Anybody know of anything on the market taller rather than wide. As in two rcds above each other if you get what I mean? From a commercial / industrial background so not up to speed with whats on the market. Also what LED GU10s are you guys using at the moment. Fitted Diall in my house about 3 years ago and still going great but pretty pricey at ÂŁ10 a whip. Only ones I could find that didn't give off that yellow or blue tint. Any better options on the market?
That's pretty decent, was thinking it was going to be around 30-35 per rcbo. Was thinking just fitting 2 6 way rcd boards one above each other as cupboard can be made taller. Ill check denmans out. Thanks for the help.
Fitted a bg board not so long ago, good to work with. Don't know whats happened to MK, Absloute ****e now. Thought about it, an option but going to look pish. Cheapest option though. Just shut cupboard door and forget all about it haha.
thinking outside the box...mount the new fuse board on its side :)
i agree the MK boards are ****e, MCB's never want to line up straight etc.
I totally agree, I used to fit MK boards then got sick of them with all the breakers on the wonk, I've got about 30 spare breakers etc for MK in one of my rails at home unfortunately.
get a 5+5 split CU from BG. mount it sideways. job done.
You wouldn't catch me mounting one vertically when it's esthetically meant to be mounted horizontally.
Reply to Different consumer units in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
