different lighting wiring | on ElectriciansForums
Discuss different lighting wiring in the UK Electrical Forum area at ElectriciansForums.net
T
tbs1983
Hi Guys, I'm from a mainly industrial background so looking for an experienced domestic sparky who can help out.
My mate asked me to change a couple of old pendants in his house for new ones.
Went there tonight to do them, in both pendants (different rooms) were 3 x double insulated single cores. One of which was connected to the line side of the rose, and the other 2 were connected to the neutral. (no earth present, not uncommon in older lighting circuits)
I thought it was strange but thought there may be a borrowed neutral case going on or something.
On disconnecting the old pendant I powered up and was surprised to see that I was getting 230v across the 2 cores connected to the neutral side.
Anyone come across this type of wiring method before? I can't fathom it out to be honest. I assume there are JB's above in the ceiling somewhere but why the need for this rogue 3rd neutral core that is seemingly live?
Any help will be greatly appreciated!
Hi what colors are the singles I did a lot of house bashing when they used single cables, it may be in your case that you have a neutral in and a neutral out, and a single switch wire, thet did supply them with a cpc but not that many firms used them. If the cables are all black, the sparky may have used a black single as a switch wire, you may have measured 230 across a neutral and the switch wire, hope this helps.
Thanks for the quick reply, the neutrals were black/black, the live was black outer/red inner.
I was definitely getting 230v across the two black/blacks.
The mistake I failed to make was to open a switch to see what was in them.
Makes total sense what your saying, in fact i'm starting to think it is wired in the way you described. in effect they just ran a single neutral from db - rose - rose - rose etc, then did the lives from db - switch - switch - switch etc, and then ran in a single switch wire from each switch to each rose.
Just wondering why I was picking up this voltage across the 2 disconnected neutrals ? perhaps my testers were playing up!
Thats right N to all the lights, L to all the switches and a SW from light to switch, I did 1000s of them, what meter were you using?
Also is there any conduit hidden in the ceiling, did a house recently where it looked like no earth on the lighting circuit, untila bit of poking and prodding revealed a conduit box that had been buried in plaster over the years
Doubt if they used conduit with double insulated singles, but stranger things have happened
Just a small martindale voltage/continuity tester. didn't have full test kit with me.
I didn't lift any floorboards or anything to find conduit or the like.
Literally just swapped 2 old roses for 2 new ones.
Pretty sure it must be wired as you described. Makes total sense now. Think my tester must have been picking up some false readings.
Thanks for the help, learnt something new again today (1970's wiring methods!)
Hi , have you put your tester in SERIES with the 2 neutrals and are picking up the voltage
being sent from one of the other lights trying to complete the circuit ? you need to make sure all other switches are off and /or lamps removed , this should explain the reading you were getting .
Come on man think about it, neutral in and neutral out, single switch wire from switch, lamps in and you are making the circuit with the tester.
Reply to different lighting wiring in the UK Electrical Forum area at ElectriciansForums.net
Yes still see the odd red white and blue out in the wild, usually without cpc, iirc that colour code was only used for a short time...could be...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
