Different makes of interlinked smoke alarms | on ElectriciansForums
Discuss Different makes of interlinked smoke alarms in the UK Electrical Forum area at ElectriciansForums.net
Paul L
Monmouth
Hi Everyone,
What are your thoughts on adding a different make of battery back up mains powered smoke alarm?. The quick back story is that there are 2 BRK (I think) interlinked alarms fitted in a property and that particular make are now discontinued. Building control now want an extra one fitted due to extra building work being done and the house owner was just going to get another make but I'm not sure if it will work with the others.
My gut instinct is just to get them to get 3 new ones but as usual they are on a tight budget so I guess I'm asking if anyone has ever fitted one of a different make and it still worked in interlink mode.
replace the old ones and fit 3 Aico. ask customer if his family's lives are worth less than the cost involved. bodge it up and it's you in front of the judge.
I totally agree to be honest Tel, it's not me doing the install because I'm not in a scam now but I did a bit of work for them many moons ago. I've looked at some of the manufacturer advice on this and obviously it not recommended good practice
It's a no brainer to be honest isn't it. For the sake of a few quid and the fact they've been there for a while just replace the lot. From vague memory I believe they have a volex consumer unit too which I think is now discontinued too.
Think they are going to have to revise their budget ?
if a customer says 7, its probably nearer 11 than 9.
Aico all the way. Fit the lithium battery ones with radiolink... Not cheap, but....
A - no mains, don't need to be on a scam
B - speed of install. 3 up in 10 minutes, time for a coffee
The two existing ones are mains wired and physically interlinked but you're right, it would probably take more time to get an interlink cable to the new position than fit new radio linked ones
You canbuy a radiolink base tpan existing wire head and add a wireless alarm
Or could , been a while since I fitted them but that would probably be my approach
That certainly sounds like a good solution. They asked me for some initial advice but I'm sure the sparky who may be doing the job would come up with something.
I always wonder when people ask things whether they are doing work themselves but I believe building control are involved so they wouldn't get away with it in this case.
Reply to Different makes of interlinked smoke alarms in the UK Electrical Forum area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
