different readings from ammeters same load | on ElectriciansForums
Discuss different readings from ammeters same load in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mikilianis
Hi I wonder if I am posting in the correct forum ,if by chance I am not then would some- one please be kind and direct me to the correct forum my query being as follows
I have 3 clip on current meters ( tong testers ) and when a load is measured I get different readings now all is very well if one just wants to check if a circuit is drawing a load , but when one has to explain the reason for the different readings ,
Meter A is a analogue meter
Meter B is a digital “ R.M.S. “ meter
Meter C is a digital meter
On an inductive load the readings are
A = 43 amps B = 42 amps C = 45 amps
On an resistive load the readings are
A = 95 amps B = 87.5 amps C = 103 amps
What could the reason be for the different readings.
The same load is used or tested by the ammeters
Mike
Hi.
Lots of things could affect the readings....different makes of tester, components, resistance of connections in leads and probe tips etc etc, tolerances.
a and c are based on an average calculation on a sine wave, b however being rms i would say is more accurate as ist based on a dc equivalent.
Reply to different readings from ammeters same load in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Have fitted those before. Not wanting to state the obvious but it is vital that the voltage inputs to the meter, L1, L2, L3 match exactly with the...
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
