Diffuse backlit label strip | on ElectriciansForums
Discuss Diffuse backlit label strip in the Lighting Forum area at ElectriciansForums.net
UK
I want to backlight a shelf-edge label strip, so I was thinking of using some kind of surface mount aluminium channel - this sort of thing:
[ElectriciansForums.net] Diffuse backlit label strip
It needs to be viewable from close to (say 30cm) without getting your eyeballs boiled, so I was planning to run the strip quite dim. Is that likely to cause a problem of uneven light, i.e. each LED being visible?
I guess the size of the aluminum profile is similar as W16mm*H6mm. For such projects, first thing you need to make sure that it will be dotless since it is only 6mm height aluminum profile. So 240-300leds/m might be ok. Eiether to be SMD 2216 chips or COB chips might meet your demand with 2 rows of 4-5mm strip lihght. Secondly, you have to control the total lumen of the strip light, which is mainly by the watt. So my recommendation is as below:
2 rows of 4-5mm SMD 2216 LED strip light with 240-300leds/m 4.8-6W/M
2 rows of COB LED strip light with 380-500 leds/m 4.8-6W/M
  • [ElectriciansForums.net] Diffuse backlit label strip
Reply to Diffuse backlit label strip in the Lighting Forum area at ElectriciansForums.net
Thank you for getting in touch! Looking forward to use your services in the future! :)
