Digital Thermostat | on ElectriciansForums
Discuss Digital Thermostat in the Australia area at ElectriciansForums.net
Spiceman
Please could anybody recommend a accurate digital thermostat that would display the present temperature of the room and also obviously what I have set the boiler to fire up.
My present old honeywell thermostat doesn't seem to be very accurate and could do with changing.
I would recommend siemens check out link never had any probs.
Siemens Room Thermostats : UK Plumbing, Online Shop
Would you know what model? I don't need it to be wireless or anything special.
Just show current temperature of room and the temperature Ive set it to operate.
Both temps to be on the same display.
thanks
thanks
Sorry haven't come across one that shows both temps unless you go for a programable one that allows you to set different temps for different times of the day.
Reply to Digital Thermostat in the Australia area at ElectriciansForums.net
U
Smart thermostat causing boiler to short cycle or something else? Hi all, When I use my hive thermostat in the way I think your supposed to...
u0362565
U
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
