dilog meter probs | on ElectriciansForums
Discuss dilog meter probs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
brucegenerator
Just did my 2391 practical .When testing Ze got an extremely high reading C&g say i cannot use thr
e meter properly but when i test on domestic reading is fine .Anyone else had this problem as the method of tet was fine .
Reply to dilog meter probs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
