Hi all,
I read that dichoric MR16 are being phased out due to heat reflection and are not advised to be used in recessed lighting.
[h=1][/h][h=1]I replaced some LV mr16 for dimmable cob gu10, and replaced the dimmers to suit. worked fine for a short time, then it stopped dimming, then stopped working........
there was 3 dimmers,
one with 2 x 5w dimmable cob on a 10-100w dimmer
one with 5 x 5w dimmable cob on a 10-100w dimmer
one with 8 x 5w dimmable cob on a 40-400w dimmer
The circuit with 8 x 5w remains functional....
So i was considering options and thought to buy better dimmable bulbs and saw these:[/h][h=1]Philips Master 240v 7w GU10 Dimmable LED Dichoric Lamp - Cool White
But my concern was with the dichoric reflector, but i could only find negative info regarding it, but that was all in reference to 12v 50w mr16, which obviously get hot enough to roast a marshmellow....
would the advisory to not put them in recessed fittings (downlights) still remain, or due the lower heat emissions of LED's would this be sweet as a nut?
cheers[/h][h=1][/h]
cheers[/h][h=1][/h]
