Dimmable led gu10 lamps | on ElectriciansForums
Discuss Dimmable led gu10 lamps in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Fitted 11 down lighters today for a customer who had bought 11 5w led lamps ( gu10 ) it states on the box at they are Dimmable but when I try and dim them they flicker like crazy , I've took one home tonight , rigged it up to a dimmer and it's fine , any ideas ?
Take your LED load, in your case 55W and multiply this by 10, this is the minimum dimmer rating that you will need - not readily available!
Unplug 7 or 8 of the lamps and see what's happens.
Even if you get the LEDs to dim, do not expect a nice smooth dimmer curve as you get when using halogen lamps - the manufacturers will catch up one day!
What type of lights were previously switched from the dimmer?
You might find that the dimmer is a standard dimmer and not an LED compatible one if she did not have LEDs previously.
I can't see the load being the issue as it's only 55 watts.
Reply to Dimmable led gu10 lamps in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
