Hi,
I purchased a dimmable touch table lamp in B&Q a few weeks ago.
I ensured I purchased the correct dimmable G9 bulbs, but on getting it home, discovered that the touch function only turns the lamp on. It doesn't cycle through the various dim levels on each touch, and the only way to turn the light off is to turn it off at the plug.
I assumed the lamp was faulty, but when I took it back to B&q today, they plugged it in to check it and it worked exactly as it should.
I got the lamp back home, have tried various different sockets around the house, but I have the same problem with it not going through the dimming levels and not turning off unless turned off at the plug.
Does anyone know why this lamp would work fine in B&Q, but not as it should do when the same lamp is plugged in at home?
Thanks,
Grant
Thanks,
Grant
