Hi all,
I hope everyone is well!
I currently have 5 downlights in my soffits controlled by a dimmer switch and a PIR security light on a timer switch and the PIR also feeds a small light beside the front door, I’m wondering if I could use the SL from the PIR to turn on the down lights as well ?
I’m wondering if it will affect the dimmer in anyway and I assume that if I have the lights switched on at the dimmer to a low setting, when the PIR turns on, it would turn the lights to their full brightness?
Currently I have a large wiska box with the feed from the DB, SL from the dimmer and SL from the PIR in (also all the relevant N and CPC) I’m wondering if I can just use the SL from PIR and just move it from the door light and put into the soffit light circuit?
I hope that makes sense, I feel like I’ve been rambling. ?
