dimmer controlled halagen lights | on ElectriciansForums
Discuss dimmer controlled halagen lights in the Talk Electrician area at ElectriciansForums.net
C
coldy82
hi i have 15 halagen lights controlled by a dimmer switch and one by one the lights keep going and when i try to replace the light it will not work i am down to my last four lights that are working . can anyone shed some light on what might be the cause
yes they are downlighter and yes they are dimmerable they have been working for about a year but when i come to replace them they will not work i have tried a swapping a bulb that was good and it wouldnt work
easiest waty to start is to replace the dimmer with a standard rocker switch. if they work then, it's the dimmer. you need at least a 1kW dimmer.
generally, yes. but my suggestion was a process of elimination (do the easiest bit first) . if the switch don't fix it, then testing the circuit after the switch would be my next step.
hi i have just check the bulbs that are used and they are 12v 50w halagen this means that they are elv has any one got any ideas
Reply to dimmer controlled halagen lights in the Talk Electrician area at ElectriciansForums.net
Neutral and live
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
