Gta_g20
Hi guys. Sorry for the sad post but I thought this was a simple plug and play...
So I have two light switches in my basement living room controlling one light fixture each independently. They are pot lights and too bright so I decided to buy replacement dimmers for both.
Again each switch is the only switch to control that single respective light.
Both original switches are single pole Leviton basic switches. I removed one switch it has 3 wires. All wires are black.
Wire a/ connects at the top screw.
Wire b/ connects at the bottom screw
Wire c/ connects at the bottom and quick connects into the back of the switch
There are several white wires in the box connected by a marette wire cap.
The issue I am having is my new dimmer switch has a green wire which I assume connects to wire A. Then two black wires which I connected one to wire B and the other to wire C.
When wired in this configuration. All electrical outlets/ sockets have no power when dimmer switch is off. When dimmer is turned on the sockets receive power, but the pot light fixture has no power.
If I connect wire B and C together the outlets/ sockets begin to work but the light fixture is still off.
I’m beyond puzzled it’s probably simple but I can’t wrap my head around it
