Dimmer switch voltage problem | on ElectriciansForums
Discuss Dimmer switch voltage problem in the Australia area at ElectriciansForums.net
T
tonmar
Hi All
Have installed a 3 gang dimmer switch and when turned on to maximum with no load only 120v but as soon as lighting flex added it was 230v. When turned off back down to 0v.Can anyone explain why? Thanks.
2 core flex from pendant used as temporary to test if working which it does when connected. Once flex disconnected but dimmer still turned on votage drops from 230 to 120v? Any suggestions?
Reply to Dimmer switch voltage problem in the Australia area at ElectriciansForums.net
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
