Dimmer switch | on ElectriciansForums
Discuss Dimmer switch in the DIY Electrical Advice area at ElectriciansForums.net
SAWbob
Rutland
Hello
I am new to the site and I was wondering if you guys could help me....I have just moved into a new house and the dimmer switch in the lounge will not turn off. It will dim but when you push the dimmer switch it will not deactivate it stays on.
I have taken a couple of photos of the switch and the wiring looks confusing...
I have the grey going to L1
Black and brown to L2
And the brown (assuming Live to the common).
Is this wired up correctly?? Its a 2way 1 gang switch controlling 7no 50w GU10 spotlights[ElectriciansForums.net] Dimmer switch[ElectriciansForums.net] Dimmer switch
I am a joiner by trade (for 26 years) and worked in the facilities management business 10 years ago where I got my 16th Edition but haven't touched electrics much sin over 5 years so I was hoping to get some advise??
Cheers in advance.
that buried choc block looks suspicious. i'd dig it out.
When I isolated the lighting circuit the kettle which I was boiling for a brew also got isolated.....so I reckon some ropey wiring has been installed here.
I will get a photo of all cables running into the back box and post a picture
Reply to Dimmer switch in the DIY Electrical Advice area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
