dimmer switch | on ElectriciansForums
Discuss dimmer switch in the Australia area at ElectriciansForums.net
LONDON (barnet)
ho guys im just wondering how dimmer switches work, (is it just a variable resistor?) also how to know which dimmer switch to use on which lights.
thanks
simpson93
when you turn the switch rather than completing a full wave cycle it will lock it on to say half a cyle or 180 degrees of a cyle, giving you more or less diffrences in power. i think?
at least thyristors don't buzz! replaced a dimmer for a client 3 times now, buzzing keeps him awake. tried telling him to switch the lights off before going to bed, arrrgh
thanks guys but still unclear about how you decide which switch to put in for which lights for instance about 6 50w downlighters do you put it on 300w dimmer?
with halogen downlights, i always add up the load, say 300 watt in your example and multiply by 2. ie 700watt dimmer nearest.
Reply to dimmer switch in the Australia area at ElectriciansForums.net
Are you sure you're competent to do this work?
