F
FOBG45ER
I am not an electrician but after some advice. I have just fitted a dimmer switch to a candelabra type light fitting with 4 candle bulbs. It is the third time I have used this same type of dimmer due to the last 2 blowing for some reason. However, now I have put this new one on the lights flicker everso slightly at different levels and don't even light up at the low end of scale. They don't flicker when turned up to full brightness. The lights worked fine with both the previous dimmers...until they blew of course.
Any ideas why this is happening and what can I do to cure this? It also happens to one other light that is connected to a dimmer in myhouse but I also have 3 others that work fine.
