Dimmer Wiring Identification | on ElectriciansForums
Discuss Dimmer Wiring Identification in the UK Electrical Forum area at ElectriciansForums.net
New Jersey
Hope this makes sense, the lights work fine, independently of each other. I'm replacing them with some smart switches and want to buy the correct type.
I think I understand the wiring in the attached picture but just wanted to make sure. The white wires combined together are the neutrals, the reds going to each of the dimmer switches are the hots, the blacks in the foreground combined together with the electrical tape are the loads? The picture is of two separate dimmer switches so I'm confused why the black wires combined together with the electrical tape(loads) are combined. Thanks
  • [ElectriciansForums.net] Dimmer Wiring Identification
It might make more sense if the black wires taped together were the live (hot), and the reds are the switched feeds to the lights.
But I'm in the UK and bemused by your wire nuts and cable colours (sorry colors)!
Reply to Dimmer Wiring Identification in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
You actually need to use the light switch since that’s where the lights are controlled from. The red wires should be your travelers going to...
