Dimmer | on ElectriciansForums
Discuss Dimmer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
haj
East Yorkshire
Hi Guys
I am covering for my mate who is on his hols got a call from a caravan park he covers asking if i can change a dimmer in the clubhouse it works 9 wall lights, as its quite a ride away i wanted to take a dimmer with me if i could do we work on 100w per light ie 900w plus reserve ?
Cheers Haj
Sounds ok but just confirm they are your standard gls lamps and nothing fancy as some dimmers require a reduction of up to 50% on the load they can handle with certain lamps, i,ve found this with gu10 lamps especially, but if you get the right dimmer they dont need allowances, its an issue with older dimmers and often overlooked by alot of people thus dimmers burn out prematurely.
Reply to Dimmer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
