Dimming fixed wall lights | on ElectriciansForums
Discuss Dimming fixed wall lights in the Australia area at ElectriciansForums.net
A
AdrianGroom
Looking for some advice please
I have a hall with 3 fixed wall lights (each have 60W linear halogen bulb). The light produced from these is too bright and I was wondering if there are any lower wattage R7 bulbs, or is there an inline box that can be connected to the feed cable that would act as a dimmer
THanks in Advance
There is an inline box that you can connect to the cable to dim the lights. No additional wiring is necessary, it simply replaces your existing switch. What is more you can select the brightness you want the lights.
You can buy them from B&Q, Homebase, Robert Dyas, Tesco (probably) and all good DIY shops.
Sorry, I may not have explained the full picture
THe switch controlling the wall lights is a 3 gang switch with 2 of the gangs (the wall lights are one of these gangs) being 1 way and the final gang being 2 way
Sorry for the misdirection
Unfortunately the existing toggle switches must be used. Looks like I will have to add a single dimmer switch to the feed. I was hoping that there might have been a dimmer control to fit on the feed (in the eves) that would have a flat head screwdriver adjustment and thereby not be available to the casual adjustment or knocks.
Thanks anyhow
Reply to Dimming fixed wall lights in the Australia area at ElectriciansForums.net
