GarryJ
Hi all.
Just looking for some help with dimming 2 x 6ft fl fittings. Only 2 on circuit and standard wiring. Feed and SL at normal switch just now. I asked wholesalers to source me a solution for the customer as he wanted them to be able to be dimmed. They came back saying change 2 ballasts in fl fittings to Helvar EL1x70sc and change switch to dimmer - Danlers DPID10VDCMB.
They said this will work on existing wiring and no extra cables would be required however looking at it to me there needs to be a 2 core run from switch position to ballast then between fittings which customer does not want. Can anyone assist?
Thanks in advance for any help
