K
knasher
Hi All,
A friend has just mentioned that when they turn their living room light off (a class 1 fitting with 3x 60w lamps controlled by a 1 gang, 1 way switch switch) the flourescent light in the kitchen goes off for about 5 seconds too then comes back on. Its controlled by a 1 gang, 1way switch.Any ideas what might cause this? Could it be the ballast in the kitchen light? Some sort of induction issue? Can't say I've got a clue really!
Be interersting to hear any of you ideas please.
Could be a drop in voltage at the fluorescent when the other light is switched on. You should be able to see this with a decent tester. Check for poor connections or terminations which might typically cause this sort of problem.
OP said kitchen fluorescent goes off for 5 secs when lounge lights are turned OFF
Ballast acts like a capacitor - seems that it is discharging somehow - back into the lounge bulbs via neutral? Only guessing here mind.
Have you checked - are both sets of lights switched on the live? Is one or both of them switched on the neutral?
Thanks for that - can VD be measured by clamp meter on R1 to get current, then measure Zs at the board and deduct Ze from this to get R1 +R2 resistance. I was then going to use V = I X R to get VD. Does that make sense?
in a word, no. visual check of both fittings and their switches. should locate problem. if not, measure voltages and see what happens when lights are switched on and off
dimming fluorescent tube
Australia
knasher,
Marvo,
