dimming large amount of downlights? | on ElectriciansForums
Discuss dimming large amount of downlights? in the UK Electrical Forum area at ElectriciansForums.net
South West
HI,
I've been asked about installing a potentially large amount of downlights in a basement kitchen/dining area. There is going to be a lack of natural light and the client wants downlights to be installed and she would like them to be dimmed too.
After doing lots of measurements of the area i've worked out she'll probably want 9 downlights over the dining area and 18 lights over the kitchen area switched from a 2 gang switch. (this is a huge basement before you ask) i might be able to slightly reduce the number but because of its lack of natural light i'm wary of this.
9x50w is 450w
18x50w is 900w
Would a 2 gang 1000w dimmer be able to dim this load properly or am i missing something.Im Not an expert on dimmers!
Or would fitting mains dimmable LED lamps be a suitable option? (would prefer this)
If anyone one has any other ideas that would be great,
Many thanks
Most dimmers specify how many/wattage for LED's, and it will be way down on the headline rating figure for resistive loads.
I have successfully dimmed 10x8W Philips + 1x 4.5W Philips, all in the same circuit using Varilight V-pro. The 11 lamps was just fractionally over the recommendation, but you won't get 18 in one circuit.
Check the dimmer data and the LED manufacturer first and tread carefully. Get it wrong and you'll have embarrassing problem.
you need to be careful with what LED lamps you are using as not all will be dimmable and most end up flickering alot. make sure dimmers are suitable aswell, leading edge? last job i did was using JCC DIMMABLE LED7 downlights with 2g richmond zano grid z500 dimmers. works perfect.
Reply to dimming large amount of downlights? in the UK Electrical Forum area at ElectriciansForums.net
