Dimming or just being dim!! | on ElectriciansForums
Discuss Dimming or just being dim!! in the UK Electrical Forum area at ElectriciansForums.net
T
tino2199
I was hoping for some advice. Recently installed 5 x 4.3w Led Gu10's in a bathroom controlled with a dimmer switch. Everything works fine except my customer wants to be able to turn the dimmer right down then press it on and for lights to come on at their lowest light level. The dimmer switch will not do this. I've tried 3 dimmer switches in total with no joy. Each time the switch needs to be at mid level before being turned down.
Anyone got any suggestions?
The problem your encountering, is that some Led lamps need more energy to turn them on, than is available when they are dimmed down and then turned off. Zano Led dimmer have a start level pre-set, which can give the lamps a boost when turning them on from a minimum dim, but they aren't cheap. Varilight have some good dimmers, and are cheaper. It might be your client might have to accept the Led lamps to be slightly less dimed when they turn them off, so than can turn them on if you see what I mean.
PS, you should use a dimmer recommended by the manufacturer of the lamps.
Reply to Dimming or just being dim!! in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
