M
mickymicky
Hi, I'm new to the forum.
I have a domestic installation with; 14No 35watt lv lamps= 490 watts.
controlled by 5No 105va 'Mode' leading edge transformers = 525Va
I am trying to dim the circuit with a Richmond (now Zano) Grid 700 rotary dimmer module that uses leading edge technology, max lv load recommended 600 watts. The system works ok until the last 2 degrees of turn of the rotary switch, the connected load then begins to pulse (flash). At the same installation I have another Richmond grid 700 dimmer controlling 8No 35watt lv lamps on 8No collingwood 60Va leading edge transformers. This circuit operates without a problem. I have swopped the switches to check if I have one faulty switch but both work on the 8 light circuit. I previously had collingwood transformers in problem circuit with same problem. Both switch and transformer manufacturers are confident that their product is up to the job. What am I doing wrong ?
