T
Thornton-IS
hi guys,
I've never installed or used a dimming lighting interface unit before, this one as numbers 1-9 on it and an lcd display. im wanting to know how this works. there is a board that is labelled up lighting system in the back fitted with breakers for isolation the spot lights in banks. does the dimming switch dim all the lights at once or does it dim each section but all together when the signal is received? sorry if this doesn't make sense its hard to explain. the reason is because i am wanting to install LED gu10 lights but theres a large number of lamps and they would defo blow if they were all dimmed together?
can anyone shed any light (pardon the pun) on how the dimming system works or suggest an alternative method to install the led lights that all dim together?
thanks - Tom
thanks - Tom
