B
buttonmoon
Hello
I am trying to repair two dimplex storage heaters. They are on dual supply from a split CU, but unfortunately I don't have access during the night which means I can't check whether the power is getting to the elements. Do you suggest continuity across the elements and from the Consumer unit then functional test input high output low. Or are there other things I could look at? Is there a thermal cutout and if so where? They are CXL range.
Any ideas would be appreciated
