Directional valve problem | on ElectriciansForums
Discuss Directional valve problem in the Central Heating Systems area at ElectriciansForums.net
T
Terry1
Hi, I have replaced a Switchmaster 3 port valve will a Honeywell valve all is working fine but the boiler header tank is over flowing (only dripping down the overflow pipe). This appears to only happen when there is no call for heating or hot water. Any ideas? I think it's a faulty valve.
To avoid changing the pipework I installed the valve upside down.
Have you got the wiring right? If both H/W and CH are satisfied the boiler should not be operating. Valves should only be fitted the right way up to avoid water ingress in the case of a leak.
Thanks for you response. I have solved the problem by replacing the hot water tank, the heating coil was split.
Reply to Directional valve problem in the Central Heating Systems area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
I
Cleaning a Magnetic Filter without an isolation valve Hello All, We have a Vaillant boiler, it has an advanced protection kit fitted that gives...
i3_happy
I
