Disabled pullcord alarm- with calling out function | on ElectriciansForums
Discuss Disabled pullcord alarm- with calling out function in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
J.C.E
Earth
After a easy enough to install pullcord system for a bungalow for a disabled person- that will call a phone number if the pull cord is tugged on
Cheers
cheers
doesn't look like it has a fuction to call a mobile number?
They want it to call out rather than just buzz inside the property
Have you read the notes? I believe there are options for external connections to another system.
You could use an SD1 autodialler and use the pullcord to close a relay and apply the negative needed to make it call out
Reply to Disabled pullcord alarm- with calling out function in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Good luck with your project and welcome to the forum
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
