Disabled toilet alarm | on ElectriciansForums
Discuss Disabled toilet alarm in the UK Electrical Forum area at ElectriciansForums.net
Sussex
Hi I’m installing a disabled toilet alarm and they need an extra beacon in the office about 100mt away. Has anyone got any suggestions as to what cable to use for this longer run
maybe? Or maybe not suitable?
I must admit I had exactly the same thought before I saw your post.
They work well and the cost of them wouldn't be far off the cable and the labour.
Now I’m awake, two more thoughts.
1 - is the same way I wouldn’t trust a nest to be a frost stat, for something like this it’s probably not good practise to use wireless.
2 - I’ve fitted a couple that are extra low voltage so volt drop over 100m needs considering
OP is this all within a building or is the office in a different building? Is it a 12/24v dc system?
It’s in a factory toilet in the warehouse. Will be 12v DC
Is the fire alarm an addressable type? If yes, then way I’ve done it on the past is to fit an input relay onto the fire alarm, connect the toilet alarm to that, then have the fire alarm sounder in the office to activate when the toilet alarm activates. Obviously different tone etc to the normal fire alarm and a bit of fire alarm programming but has worked in some big schools etc
I agree, I thought after my post that this is a safety system, and the product I mentioned is not designed for that application, so is a really bad idea!
Maybe use the cable to switch a relay, and have the beacon powered at the remote (office) end?
And use decent gauge cable to minimise the volt drop.
Really need to know the current consumption of the sounder (sorry - beacon!) that's going to be used. The couple of piezo sounders I looked at on the interweb take 250mA to 370mA, so this may not be too much of a problem, unless the sounder is a lot more than that.
1mm sq cable would drop about a volt with those figures.
Really need to know the current consumption of the sounder that's going to be used. The couple of piezo sounders I looked at on the interweb take 250mA to 370mA, so this may not be too much of a problem, unless the sounder is a lot more than that.
Good point. Could well be not much more than a relay coil.
Reply to Disabled toilet alarm in the UK Electrical Forum area at ElectriciansForums.net
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
