Sparkboy
I need to install a cu in a kitchen but wanted to make sure I got the discrimination right and hopefully also inside regs.
Main CU is in basement and is dual RCD, can I use a 32amp mcb on one side of the rcd and run t&e 10mm to the new CU in kitchen and use just a main switch with additional MCBs.
or
come off the main switch in basement with an rcbo.
or
would I need to put 10mm swa from an isolator off the Henley block, and then put another dual rcd board in the kitchen?
Thank you.
or
or
Thank you.
