SpannerSpark
Hi all,
This is my first post, hopefully someone will be able to confirm my suspicions. I am newly qualified so need a bit of hand holding sometimes. I am most probably going to use this piece for elecsa part P registration as its notifiable, so better get it right!
I am fitting a garage with a small CU (16A radial sockets, 6A radial lights), 30mA RCD protecting the two circuits. The garage will be fed from a CU in another larger building which has a 10-way CU but only has 2 of the ways being used so there is plenty of space.
The 10-way CU incoming supply is TT and the 10-Way CU already has 30mA RCD on it. Therefore i want to find the best way to ensure some discrimination between the 2 CUs (i.e a fault in the garage doesnt trip both garage 30mA RCD & larger building 30mA RCD). I was going to to add a non-RCD protected neutral bar to the larger building CU and take the L & N from the input of the 10-way CU RCD, feed it to a 30A Type B in the 10-way CU and then on to the garage. hence the only RCD protection for the garage is in the garage CU. Is the best solution?
Also I am exporting the earth from the larger building CU to the garage (i.e. the garage will not have its own ground spike) is there a preference on this? I think either exporting it or adding a garage spike should both be fine. FYI The garage will be fed by fed by 4mm 3-core XLPE SWA. The distance between the buildings is @10Metres
Any help welcome. Tks
