discrimination | on ElectriciansForums
Discuss discrimination in the Australia area at ElectriciansForums.net
B
blenki
Hi with a 100A 1361 cut out and 100A main switch in the CU , when fitting a switched fuse unit in a long meter tail run would you make it 80A to allow for descrimination of the fuses. Cheers
Are you saying you would put a 100A in , i thought you had to apply discrimination to ensure that if theres a fault on the meter tails the switched fuse unit would blow and not the 1361
Reply to discrimination in the Australia area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
I think it's more towards what the future brings with them and their ability to measure true power. Half remember a video from bigclivedotcom that...
