Dishwasher/Hob | on ElectriciansForums
Discuss Dishwasher/Hob in the Electrical Appliances Forum area at ElectriciansForums.net
L
Lioned
A customer of mine has a small kitchen and wants me to fit a dishwasher in the unit below the hob.I am trying to think of a reason why not as its a bit unusual,but i cant think of any reason why not but would like opinions please.
Unusual it maybe, but i can't think why you can't comply with your customers request either. As it's a small kitchen, i guess any and all available space needs to be utilised to best use!!!
I was thinking that in many 'integrated appliances they supply a self adhesive foil to stick under the worktop above presumably to stop the rising heat damage,but then many ovens are installed under hob units so i would think the underside of any hob would be designed to deal with that.
Just never come accross it before and it will look a little unusual.
Will check the instructions for the hob though. Thanks.
The other reason for the foil is to stop water penetration of the underside of the worktop. Dishwashers can give off water vapour /steam in use or if the door is opened straight after it's finished. You may get condensation in the hob?
Reply to Dishwasher/Hob in the Electrical Appliances Forum area at ElectriciansForums.net
Could you tell her you're gonna give it a quick test as she is unsure where the paperwork is? That would give you a better idea of overall...
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
