Distribution board in showeroom | on ElectriciansForums
Discuss Distribution board in showeroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Edinburgh
Hi guys, went to price a job today in a Hostel. When looking at the mains position i was shown to the room containing it and to my horror it is in the showeroom. As you can see from the picture , the Board itself has been boxed in with plywood and has a hasp on it it is 700mm away from the shower (out of zone ). Aparently it used to be a small kitchen that had been converted. No circuits are rcd protected and it is a DB is of steel construction. I tried to advise that it was not right and maybe the room use should be changed again. What do you think[ElectriciansForums.net] Distribution  board in showeroom[ElectriciansForums.net] Distribution  board in showeroom
Need a bit more here fellow like has the shower got a shower tray. If not the zone is 1.2m. the cupboard is locked so needs a tool (key) for access so may be considered outside the zones. Anyhow all the circuits in the location need to be protected by an 30mA RCD
the shower has a tray and it is out of zone 2. There is no rcds as, All supplemetry bonding and main bonding is in place so rcds can be omitted ( unless the shower manufacter calls for it)
I would be inclined in a place like that to strongly suggest RCD protection.
also you may have supp bonding in place, but are other circuits mechanically protected in walls? Do cables run in safe zones, judging by the fact there is a CU in a converted bathroom i would say...........
Sent from my GT-I9100 using Tapatalk
Sorry jamie-spark but reg 701.411.3.3 requires 30mA for all circuits in the location. The fact that the origin is in the location the circuit not related to the shower room will require RCD
The current Regulations require that all circuits of the location require RCD protection.
That will mean the circuit feeding the DB will have to be RCD protected.
There are no exceptions to this requirement for skilled or instructed persons.
NmC/Spinlondon
can see what u guys are saying after i read th BRB. I read the fact that supplymentry bonding may be omited if all circuits entering were protected by an rcd and took it as the other way too. I cant for abvious reasons ( protection by seperation of circuits ) put the supply circuit on an rcd as it controls 20 circuits on that floor and even if i change the board and put rcbo's on the outgoing circuits, I will still have the supply cable rcd 30ma protected and there will be no discrimination between the tripping of the supply rcd and the out going ways
NmC/Spinlondon
There are three options to my mind.
One is to provide 30mA RCD protection to the distribution circuit.
Another is to move the DB, into another location.
Another would be to build a floor to ceiling cupboard around the DB, which would effectivly place the DB outside of the location.
Spinlondon. I am of your thinking the db is just inside the door way. I think partition it of and make it a hallway . Then it would only require the shower room circuits to be rcd protected. I think he would be happy with that if it ment work could progress. And marvo that would take care of the IP rating.
Reply to Distribution board in showeroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There is also the ongoing problems if this is a gendered changing room.... For example, 2 or 3 burly male soldiers (you said it was an officers...
A
pocket door tiling I'm converting a small bathroom in to a wet room. It has a sliding pocket door. I was going to tile the whole room with 600 x...
ahearsum
A
