Distribution Board | on ElectriciansForums
Discuss Distribution Board in the UK Electrical Forum area at ElectriciansForums.net
Sorry didn't give enough info on my previous thread. Looking for an 8 way (8 three pole mcb's) three phase dist board. Max height 600mm, Max width 410mm. Cheers.
Schneider KQ Loadcentre boards are my go to but I think you'll struggle with the width you're looking for as most are over 450mm I believe.
Reply to Distribution Board in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Useful to know. In my case there will be 150x150mm trunking at top/bottom and almost certainly I will be using tri-rated cable, probably 70mm...
