Diversity Factors | on ElectriciansForums
Discuss Diversity Factors in the Electrical Engineering Chat area at ElectriciansForums.net
Nairobi Kenya
Hello people,
I'm designing switchgear for a residential estate, of about 60 houses, specifically the protection for the incomer. Is there any provision in the British Standard that advises on diversity for such a large number of household units?
What country is the estate being built?
In the UK most DNO's allow 2 or 3 kW per dwelling as long as there is no electric heating.
so 60 x 2 = 120. the next up standard size of transformer is 200kVA.
Can’t imagine electric heating will be a requirement on this one ?
No, but air-con may be an issue. I know the OP says that they use British standards but I think there will be a big difference between a standard UK house and a Kenya one.
Yeah, thanks a lot for this, the weather is not too extreme here and the cold and warm days are tolerable without electric devices.
I was thinking on the lines of say, NEC 220.84, if there's any document in the British Standards that may be an equivalent.
Reply to Diversity Factors in the Electrical Engineering Chat area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
The locations are defined by Groups relative to the procedures which are carried out.
