Diversity for air conditioning | on ElectriciansForums
Discuss Diversity for air conditioning in the Australia area at ElectriciansForums.net
J
jonboy1
Hi all, I have a question relating to diversity allowance for air conditioning units (ACU). I have been asked to install 6 no. three phase supplies for acu's in a school.
These have starting 14A Running (max.) 29A each.
Using the on-site guide (an old copy) I have used option 2 as guidance (Heating and power). I calculated total demand at 121 amps with the diversity applied. Can somebody confirm this is correct or is there now an option for ACU's.
Many thanks
Jon
Diversity is down to the design engineer
Are the units heat pumps - which mean they will run in Winter
Are they all starting together
The starting currents on a AC unit are very short ( not like a SD fan)
Get the correct data RC & SC and the time of the start from the AC guys
Then plot them into the current time graph of the supply breaker/breaker to ensure they will not trip
If running current of each unit is 14amp x 6 = 84amp total run current
I think what jonboy is concerned about is the total starting current which you cannot apply diversity to, if they all start at once.
you can apply diversity to only the SC if you staged the starting of them but that would not be practical in their use
eg they would probably have independant control loops
so I agree with ian.settle
Reply to Diversity for air conditioning in the Australia area at ElectriciansForums.net
