Hi all,
I'm looking to install a Mira Sports Max 10.8kw shower and wondered what size cable and fuse I need to use?
I live in a top floor flat with loft access so I plan to run the cable straight up into the lost from the fuse board and then back down into the bathroom ( approximately 6 metres of cable needed) .
Also am I right in saying that the supply cable should go straight to the pull switch and then I run another cable from the switch to the shower itself?
