tbaine01
Discuss Diy Automatic Transfer Switch install, 194 and 23 wires in the DIY Electrical Advice area at ElectriciansForums.net
All my life red is positive and black negative. I was under expression the 194 was 12v + and 23 was the ground to complete circuit. This switch is tagged 194 wire black and 23 red, Just like an apinion View attachment 110601
Generator side, 23 White, 194 Red, 0 BlackAll my life red is positive and black negative. I was under expression the 194 was 12v + and 23 was the ground to complete circuit. This switch is tagged 194 wire black and 23 red, Just like an apinion View attachment 110601
The transfer switch seems normal and that’s the 12vdc to active the transfer switch. That’s confusing on the other end but are they not a wiring diagram somewhere on the equipment. A picture would be helpful of a wiring diagram.Generator side, 23 White, 194 Red, 0 Black
Reply to Diy Automatic Transfer Switch install, 194 and 23 wires in the DIY Electrical Advice area at ElectriciansForums.net
