DIY blue flashing lights - choosing lights | on ElectriciansForums
Discuss DIY blue flashing lights - choosing lights in the Lighting Forum area at ElectriciansForums.net
J
JamieJ
My dad is an emergency driver. All he has is a dash light that I bought him from amazon last year. Since my dad is an electrician I thought I would get him some blue LEDs so he can make his own lights as he complains about the price of emergency lighting.
Your post is a trifle confusing Jamie, where are you intending to fit these LEDs and what have they got to do with emergency lighting?
Since my posts of links to the products i was going to buy was removed I'll just copy the specs
Blue 10mm LED
  • Quantity : Package of 20 Pcs
  • Emitted Colour : Blue
  • Size (mm) : 10mm
  • Lens Colour : Water Clear
  • Peak Wave Length (nm) : 465 ~ 470
  • Forward Voltage (V) : 3.2 ~ 3.8
  • Reverse Current (uA) : <=30
  • Luminous Intensity Typ Iv (mcd) : Average in 8000
  • Life Rating : 100,000 Hours
  • Viewing Angle : ±10°
  • Absolute Maximum Ratings (Ta=25°C)
  • Max Power Dissipation : 80mw
  • Max Continuous Forward Current : 30mA
  • Max Peak Forward Current : 75mA
  • Reverse Voltage : 5~6V
  • Lead Soldering Temperature : 240°C (<5Sec)
  • Operating Temperature Range : -25°C ~ +85°C
  • Preservative Temperature Range : -30°C ~ +100°C
Packages Includes:
8000mcd 10mm Blue LED x 20pcs
Pre-Wired Blue:
  • These LEDs are designed for 12 volt applications. Complete with built-in current limiting resistors
  • Just connect the positive (+) and Negative (-) wires to your battery or power supply.
  • Quantity : Package of 20pcs
  • Wire Length: 20cm
  • Emitted Colour : OCEAN BLUE
  • Size (mm) : 5mm T1 3/4
  • Voltage (V) : 9V ~ 12V
  • Luminous Intensity Typ Iv (mcd) : Average in 10000
Packages Includes:
Pre Wired 12V 10000mcd 5mm Blue LED x 20pcs
Basically emergency lighting is very very expensive. Were talking ÂŁ60 per light.
So I thought since my dad is an electrician why not buy some parts so he can make his own
If your dad is to be fitting them then it would be best to ask him what he wants and what will be compatible with his vehicle and his needs. You don't want to splash out on something that is not suitable, and he is best placed to make the decisions about what equipment is needed.
it costs ÂŁ5 for 40 LEDs
I wanted it to be a surprise for Christmas :(
Welcome to the forum.
The prewired LEDs state they have current limiting resistors which means you do not need to control the current and can connect them directly to the power supply without them burning out.
I think it might be a nice gift. But you may need to supply a few more bits so that your dad can make the assembly as soon as possible.
An obvious inclusion would be a means of causing the lights to flash.
Initially an indicator flasher springs to mind but the standard types may operate the LEDs whilst they are off as well, as they have simple circuitry, so it would be best to make sure you get an LED flasher unit (cheapest ready to use thing available).
Inclusion into light fitting on a car can be complex as they is often limited space and wiring potential.
Hope it works well.
Hope it works well.
My dad has a seperate battery in the back for his radios anyway and they are already wired so I dont think wiring will be a problem as there is plenty of space. I will look into a flasher unit is there any u can recommend that will be compatible with the pre wired?
Reply to DIY blue flashing lights - choosing lights in the Lighting Forum area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
