DIY - Detached garage | on ElectriciansForums
Discuss DIY - Detached garage in the DIY Electrical Advice area at ElectriciansForums.net
England / United Kingdom
DIY ADVICE / POST
Hi All,
It's my first post on this forum, I hope I'm posting correctly, finding the guidance of where to post a little confusing!
Intro
Just after some advice on my current set up and whether I can and can't do this without getting a sparks in. For reference, I'm happy undertaking any electrical work I'm allowed too, and would like to think I'm competent in that respect (have added spurred sockets in the main house, repaired broken cables and had them tested by a sparks etc). Anyway, will try and be concise.
Situation
Detached garage circa 35m from house. Dedicated 2 way Wylex fuse board in house (grey box shown bottom of picture). This has one 30 amp rewireable fuse that feeds the garage. Other end of cable (in garage) has another 2 way fuse board (same unit as in house). This has one 5 amp rewireable fuse and one 20 amp rewireable fuse.
Problem
The 20 amp fuse is used for a radial on 2.5mm T+E and pulls close to 20 amps (4.5kW of heaters & other equipment). I want to increase this to 23 amps (5.5kW of load), but this can be on 2 separate radials as I ideally don't want to upgrade the radial to 4mm.
Questions
1 . Would there be a safety reason that the garage supply cable has a 30amp fuse one end, and 25 amps the other? I'm presuming that they were installed this way so that 1, the garage would trip first for convenience or 2, because the original owner wanted two circuits in the garage and you can't get two fuses that add up to 30amps.
2. Is it absolutely necessary to replace the old Wylex unit in the main house, that feeds the garage, considering this works fine and would have been compliant when installed. Note - I know I would definitely need an electrician to do this.
3. My plan is to replace the old Wylex unit in the garage with a new consumer unit with 3 MCBs, 1 6amp for the lighting and 2 16amp for the radials. Is this reasonable?
4. Understand that adding a new circuit is notifiable but would this be classed as a new circuit as I am in essence altering the existing?
Thank you for any help / advice
[ElectriciansForums.net] DIY - Detached garage
Reactions: Dan
Reply to DIY - Detached garage in the DIY Electrical Advice area at ElectriciansForums.net
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
But why do they want a CU? That won't give them any more available power than they currently have. As it is a 2.5mm SWA cable it is presumably a...
davesparks
