Blackemerald
Hi all, looking for advice, based in the UK.
I have a 30m long garden with shed at bottom that I want to run an extension lead to on a permanent basis. Use is for power tools (drill, jigsaw) plus lamp in the winter so neither constant nor heavy usage.
Currently I run a single 40m reel extension lead down to the shed when I need power. Plugs in at a new (2 year old) weatherproof socket. Fine but a bit tedious to do over 30m garden each time.
Burying an armoured cable isnt possible as the shed is on paving which covers a good 10m of the garden length.
My thought was to thread the cable through a new garden hosepipe, run the hose on the surface alongside the fence/hedge. The plug end would be protected in the weatherproof socket and the reel end would live in the shed (pass cable and hose through wood shed wall). Keep it on the surface at all times to be visible.
Is this safe? Thanks
- TL;DR
- Can I thread an extension lead through hose pipe and use it as a permanent power supply for a shed.
