DIY first time wiring light | on ElectriciansForums
Discuss DIY first time wiring light in the Lighting Forum area at ElectriciansForums.net
Mccjen
Uk
Hi
I just replaced my folks outdoor floodlight but now worried I have done it wrong it is working but wanted to check.
it has a junction box all seemed easy however when doing it I spotted cable had 4 wires…the black one wasn’t used before so I just ignore it..now worrying I have done something wrong.
Wired yellow/green, brown and blue like normal
TL;DR
Amateur wiring help please
What colour were the wires coming from the house, if what you described sounds like a 4 core flex ( and what is on the fitting)
Did the fitting come pre flexed?
Can we have a photo of the joint you made?
If you changed the light as it was previously connected, you shouldn’t have gone far wrong.
Reply to DIY first time wiring light in the Lighting Forum area at ElectriciansForums.net
That doesn't look a very big cable for the supply to a property. Could it be a 3 phase supply, in which case they'd be a bit more of a suitable...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
