DIY outside motion sensor | on ElectriciansForums
Discuss DIY outside motion sensor in the DIY Electrical Advice area at ElectriciansForums.net
New York
Hello all. Just looking for others opinion on this set up. From what I remember my outdoor motion sensor light is hooked up from an indoor receptacle. I added a light switch as well to reset/ turn off the outdoor light. All are on a 15 amp circuit. My question is that is this set up ok? I believe it is run by 14gauge romex to the outdoor light. It is pvc conduit that goes up the wall and I think it was sealed and painted with ‘great stuff’. Wondering if I should remove the romex and add thwn/thhn wires (the correct wires for conduit) in the conduct. Any information is appreciated. Thanks
- John
[ElectriciansForums.net] DIY outside motion sensor
- John
As long as the existing wiring is approved for outdoor use and everything is working as planned then there is no need to replace the wiring.
Reply to DIY outside motion sensor in the DIY Electrical Advice area at ElectriciansForums.net
I’m running a feeder from main panel into spa panel that I’ll mount on exterior wall of house , will run through basement ceiling. Im thinking to...
Good luck with your project and if you have any questions you know where to get your advice
Alex first off why would you run steel conduit instead of PVC pipe, it’s a whole lot cheaper and faster to install. If as you say future proof it...
I did and I thank you for that. You really opened my eyes in how this actually works. Thank you.
No one has tried to delete your account, if a staff member wanted to do so it would have happened. I deleted some of the early posts which weren't...
