Thank you. You can connect you figurines using the connector leads without a resistor to the eight 4.5V 30mA outlets instead of using a battery/batteries, one output and lead for each battery you substitute for - do not use the the higher amperage outlets though. One 30mA outlet replaces one battery in a compartment eg: in the head. Please confirm all works fine.
There is something in this which talks about what the higher amperage outputs can be used for - meant nothing to me though.
View: https://www.youtube.com/watch?v=r8JXlyZ3TpA
