I am making a security door system with reed type magnet switch. I have tried it on my desk and it works. I can set the time to stay on for several minutes. I was wanting one which would stay on even if they closed the door back quickly. This does that. My questions are: Do I need a stepping 12 volt power supply to power the relay? I am using a 2amp 5 volt phone power supply. Should that be larger? Are there any resisters or additional componnents I need? Can I "dasiy chain" them so more than one Reed swithch will trigger it?ALARM SYSTEM.jpg
looks like you need 12V for the relay coil
The relay has a power supply of 12 volts in and says it can handle 110 volts out which the alarm is. I am going to use a cellphone activated plug (WeMO) which will allow me to turn the power on/off to the 5 volt power supply as I leave and return. I will install inside a closet near the WiFi network because I am not sure if the circuit board can handle the hot temp in the attic during the summer. I have 3 doors. Can I dasiy chain them or will I have a current loss which will not activate the relay? These could be as far away as 40 feet from the door reed switch to the main circuit board.
Russellville, Ar (Ozarks)
United States of America
DIY Security System Do I need Steping Power Supply
Security Alarms, Door Entry and CCTV (Public)
ArkBigFoot,
ScottPiligrimm,
