DIY Solar Panel Installation In Shed | on ElectriciansForums
Discuss DIY Solar Panel Installation In Shed in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
C
cherryman
Hello,
I have been given an 80W Bard solar panel similar to the one in the link. (https://www.amazon.co.uk/gp/product/B00BSUL6JK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
I am looking to install on my shed as I cannot provide a mains supply. I have 2x 9Ah 12V batteries and have a small consumer unit etc..
Can anyone advise on which charge controller I should use and what rating? Also what size inverter? I amlooking to use mainly for lighting and one radial for some 13A sockets to powera charger or use of the odd power tool (drill).
Any advice is appreciated :)
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Hi,
I don't know the first thing about solar panels, however, I can tell you that you will need a heck of a lot more panels that a single one for what you want to do.
I would probably say your best bet to use 12v for lights etc.
Reply to DIY Solar Panel Installation In Shed in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
